Hi OCR.space team,
We are testing OCR.space PRO with OCREngine=3 for automated document processing.
We found a reproducible case where Engine 3 returns text even though the submitted image has no visible text. The returned text looks generated/instruction-like rather than extracted from the image:
Watermarks should be wrapped in brackets. Ex: OFFICIAL COPY. Page numbers should be wrapped in brackets. Ex: <page_number>14</page_number> or <page_number>9/22</page_number>. Prefer using ☐ and ✅ for check boxes.
The API reports this as a successful OCR result:
"OCRExitCode": 1,
"IsErroredOnProcessing": false,
"FileParseExitCode": 1,
"ErrorMessage": "",
"ParsedText": "Watermarks should be wrapped in brackets..."
Request fields used:
endpoint: https://apipro1.ocr.space/parse/image
language=auto
OCREngine=3
scale=true
isTable=true
detectOrientation=true
Changing these did not stop the output:
scale=false
isTable=false
detectOrientation=false
language=eng
Images that reproduce the issue:
https://i.imgur.com/dSQGqpm.png
https://i.imgur.com/4kPrtBJ.png
https://i.imgur.com/LOSYvUV.png
https://i.imgur.com/MLxf6xS.jpeg
https://i.imgur.com/WjVlLiW.png
https://i.imgur.com/uc6AgOG.png
https://i.imgur.com/cb2ZAoS.png
https://i.imgur.com/BqVqsSj.png
Some crops did not return text and instead timed out:
https://i.imgur.com/HCIIVpn.png
https://i.imgur.com/xv01koI.png
https://i.imgur.com/k9MnT4q.png
https://i.imgur.com/pTdL01N.png
https://i.imgur.com/OVJhDB4.png
Engine 2 returned empty text for the original image, which is what we expected.
For our use case, the problem is that Engine 3 returns this with a normal success response, so our pipeline cannot tell whether the text is actually present in the submitted image.
What configuration, preprocessing, or response fields do you recommend using so that automated document processing can avoid accepting this kind of false-positive OCR output as real extracted text?
Thanks!
