Just wondering if it’s possible with this tool to schedule a daily macro to run at ~3AM to navigate to various (5 different) websites, login, and click ‘download’ to download a CSV file?
Any pointers would be super helpful.
Thanks in advance,
Thanks in advance,
Yes. I personally use task scheduler (windows) for all of my macro scheduling and it works flawless using the UIVision command line.
You RPA case would be no problem for UI.Vision.
