Is there a way to disable the red rectangle when using XClick or other feature that cause it to show up? It’s causing issues with my OpenCV Python script because it is is staying on screen
Hi, to avoid the “image found” boxes you can run the macro in desktop automation mode.
Thank you, that seems to have worked. Though it would be nice to have the option without resorting to desktop automation mode.
