If one window is open and above that one popup tab is open after closing tab. how to return to previous first window ?
Can you post a screenshot of this situation?
I want to return to previous first window and click on Excel button but this action not perform because not connected to that previous window. Also I try iframe, frame, and tab documentation to resolve this issue.
@Plankton give reply to above screenshot.
This is not really a new browser tab, but more of an popup window, or? If it would be a browser tab, you could just use selectWindow | TAB=CLOSE.
So to automate this popup window, I recommend to use desktop automation feature auf Ui.Vision - it helps also with web automation sometimes ![]()
In your macro, add:
- XDesktopautomation | true
- Xclick |
- XDesktopautomation | false
