Hi guys, me again
Trying to replicate this code, but it does not seem to be working, have tried some variations, but no luck.
Keep getting the error code in red == not defined?
Hi guys, me again
Can you please post the macro source code here?
Hi there, here you go
“Name”: “does not work”,
“CreationDate”: “2019-2-7”,
“Target”: “https://a9t9.com/”,
“Command”: “storeText”,
“Target”: “//*[@id="content"]/div[3]/div/h2[1]”,
“Command”: “echo”,
“Target”: “Name var = ${name}”,
I have tried store and storeText can’t get either to work
Before storeText, add
store | --- | name
so that the variable name is defined, even if the value does not exist on the page.
Thanks I have tried that and it gives the same result
“Name”: “temper – scrape and store from URL”,
“Target”: “—”,
“Value”: “name”
“Value”: “name”
“Command”: “echo”,
each command works, but it breaks with
"Target": "Name var = ${name}",
It is telling me the name is not defined, but we set that value twice. Also, since I copied this example from the documentation, I would have expected it work since it is as far as I can see the same thing.
Trying to replicate the example from here
https://a9t9.com/kantu/docs/selenium-ide/storetext
| Command | Target | Pattern/Text |
| open | https://a9t9.com/ | |
| storeText | //*[@id=“content”]/div[2]/div/h2[1] | name |
| echo | Name var = ${name} |
The locator in the demo code no longer works (page has changed), but after fixing this the demo macro works fine for me.
Output is: [echo] Name var = Visual Web Automation
Code:
"Name": "1var",
"CreationDate": "2019-2-8",
"Target": "https://a9t9.com/",
"Command": "storeText",
"Target": "//*[@id=\"content\"]/div[2]/div/div[1]/div[1]",
"Value": "name"
"Value": "green"
Thanks for trying
I copied that JSON code, created the script and same error as before, the demo locater is not where the error is being reported, as it says “[error] variable “NAME” is not defined” on the echo function - hmm – lol
soon as I run echo it changes to !STAUSOK == false
Very mysterious… can you try the same macro in another Kantu, for example Kantu for Firefox?
tested on my mac – works fine, but that’s another machine, not testing on FireFox
Hmm, It worked when I copied the JSON – well worked at one point, I am wondering if there is some kind of JavaScript Conflict with another app or something – I turned stuff off, but not luck as yet
I have tried this super simple version too
“Name”: “temper”,
“CreationDate”: “2019-2-12”,
“Target”: “12345”,
“Value”: “myvar”
“Command”: “echo”,
“Target”: “${myvar}”,
“Command”: “type”,
“Target”: “id=phone”,
“Value”: “${myvar}”
basically the var here is pre-typed in as 12345 and even here I get [error]variable “MYVAR” is not defined
I can get the code to work on FF using the Kantu site, but it refuses, the same code does not work on the site I am using.
I can see it copies the var fine, I can see it sitting there, but can’t echo it out – any ideas?
