According to this post: [Confirmed bug] Why is my Kantu still auto-closing after running a script? - #6 by Timo v3.5.17 uses the new syntax of 0 & 1 instead of true/false for bookmarks. However I’m on v3.5.17 and 0 does not keep UI.Vision open, it auto closes every time (default). If I put in false, it will remain open which is the old syntax.
Issue confirmed, it will be fixed with the next update. Thanks for reporting it!
This issue is fixed with V5.5.3.
Note that closeKantu (the name) is deprecated, it is now called closeRPA. See UI Automation Open-Source Selenium IDE plus additional features, iMacros alternative
